Home > Technical (L322) > No low oil pressure warning indicator
GraemeS
Australia
My MY12's owner's handbook shows the existence of a low oil pressure warning indicator but none is visible in the short lamp test on start-up. Do other MY10-12's show this indicator?
Post #530896 14th Oct 2019 9:23pm
That would depend as to weather the CCF is turned on sir... Most are not from experience Shocked
Post #530909 15th Oct 2019 12:04am
GraemeS
Australia
Thanks Craig. I anticipated a CCF setting but couldn't see an appropriate one using my IDTool. Can you suggest which setting please?
Post #530922 15th Oct 2019 2:53am
Not without sitting in your spec car Graham... It’s in the full untested CCF list! Probably not in the short list sir...
Post #530942 15th Oct 2019 8:37am
GraemeS
Australia
Thanks Craig.
Can you confirm that you have seen it using an IIDTool please? I had another look at the full untested list but still didn't recognise any option that might do the trick so presumably I'm misinterpreting the description.
Edit: After having had a discussion with my son who has a MY10 3.0 D4 albeit with the instrument cluster s/w updated to MY14 or possibly MY16, which does not have a low oil pressure light, I have concluded that the light is no longer provided, instead replaced by a low oil pressure message if pressure becomes low enough after engine start-up. My CCF and the 3.0 D4 have a setting for a low oil pressure message, but none for a light.
Post #530949 15th Oct 2019 9:25am
