Home > Maintenance & Mods (L322) > Locking nut broken
Benner91
United Kingdom 2007 Range Rover SE TDV8 Java Black
Locking nut broken
Hi I have a puncture driver side front 1997 tdv8
When trying to remove locking nut bits of it broke I’m now stuck will this tool from Halfords work has anyone tried it thanks in advance
Post #530899 14th Oct 2019 10:36pm
Not if its an L322 you have? The lockers are made to spin in the middle if you attempt to remove them without the correct key! ie that tool!
Go to a JLR garage (main dealer) with your broken key and buy a new one! (they only do around 10-12 different keys) A PITA i know but its the easiest was sir
Post #530908 15th Oct 2019 12:03am
Benner91
The key is fine it’s the bolt on the wheel that’s broken
Post #530936 15th Oct 2019 7:27am
Oh! The only way now is to have them drilled out by a specialist!!!
Post #530940 15th Oct 2019 8:28am
You could try going at it with a hammer and cold chisel to see if you can get it to turn....
Then replace your locking wheel nuts with standard ones Wink .
Post #530945 15th Oct 2019 9:03am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
This outfit removed one for me without any difficulty. Cost me £20 as I called in to their premises.
http://www.dynomec.co.uk/locking-wheelnut-remover.html
Might be worth seeing if there is anyone local or mobile near you who offers the same service. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #530946 15th Oct 2019 9:11am
nino_nino
only way I was able to take my off was with grinder and cut off wheel + dremel tool with cut off wheel and than hummer this in the nut,
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #530959 15th Oct 2019 10:57am
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
And this is why I removed and replaced my locking wheel nuts with standard wheel bolts.
I’ll risk my alloys being pinched. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #531031 15th Oct 2019 8:39pm
This is why locking wheel nuts should be fitted with greased threads and never over-tightened. If there is the slightest doubt about there condition they should either be replaced by new or replaced by plain nuts. Assuming you can get them off at all.
Some designs are far better than others.
Post #531032 15th Oct 2019 8:54pm
DrRob
Ditched mine an hour after purchase and got 5 normal ones on each corner Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #531034 15th Oct 2019 9:07pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Ditto for locking nuts off
My thinking is if they can jack the dam thing up and lift them Censored wheels off they can have them Rolling with laughter
Post #531040 15th Oct 2019 9:24pm
