![]() | Home > Technical (L322) > Boost /turbo issue |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Welcome to the forum Mark
| Mark williams Member Since: 19 Oct 2019 Location: Usk Posts: 7
Thank gdrr
Apologies for the typos
Yep the codes would help. But sometimes (like my post above) they don't always give you the right steer.
Thanks GGDR
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403
Welcome Mark, have you recently tried reversing up a steep hill? You can provoke a high level of turbo waste gate chatter that way!
Hi Craig
Would the secondary turbo valve cause this or a boost solenoid or something of this nature |
Definitely needs the codes reading/further diagnostics running... |
Finally packed in ,turns out the turbo actuator has failed and was jamming tehwastegate closed,
| All times are GMT |
