Home > Technical (L322) > Park assist not working
Rude
United Kingdom 2010 Range Rover Vogue SE TDV8 Alaska White
Right.... I’ve checked and lots of topics about parking sensors. Mine is different. The parking button on the centre console isn’t turning on the park assist. When you engage reverse the camera works but the sensors do not. A fuse or something more sinister? Where to start...?
Thanks all
Post #531571 20th Oct 2019 7:33pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Has it ever worked in your ownership? 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #531602 21st Oct 2019 8:37am
Any tone from the front or rear? Even briefly? If it’s completely dead then yes your correct sir, check fuses first... Then it’s a plug it in job for diagnostics. If no fault codes check the PDC ECU is in the list of ECU’s found! 👍
Post #531604 21st Oct 2019 8:44am
Rude
Thanks chaps
Used to work fine. Then stopped. It went intermittent for a couple of days then nothing. No tone whatsoever. And the switch won’t work. Not even lighting up the red bar.
I know there should be a sound from the sensors themselves which I need to check too.
Fingers crossed just a fuse.
Cheers
Rude
Post #531719 21st Oct 2019 8:52pm
Rude
Bizarre. Worked fine today then stopped working again... loose wire or something more sinister...???
Post #532214 26th Oct 2019 7:30pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Mine are doing the same idd tool says sensors are working
Post #532223 26th Oct 2019 8:37pm
Danwilderspin
I’ve got the opposite mine works but iid tool can’t find the module Sad Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #532287 27th Oct 2019 2:50pm
