Home > Technical (L322) > Cylinder order
Danwilderspin
Cylinder order
Hi everyone
I’m trying to work out on my 4.2 which cylinders are where.
The lr wm says starting at the front right is 1234 and left 5678.
Auto data however says right 1357 left 2468... also I looked in the jaguar wm and it says this too...
And will all code readers correspond to the correct cylinder numbers? I was tempted to disconnect a coil and start it for a minute to look at the fault to work it out - is this a bad idea? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531798 22nd Oct 2019 4:11pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Im posting so i get an email to say some one knows the answer
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #531911 23rd Oct 2019 1:19pm
from the WM [link in wiki]
Post #531915 23rd Oct 2019 1:41pm
Danwilderspin
Hi Stan
Yes that where I looked but thinks weren't adding up and the fact it was the same as the m62 confused me I found a post on another rr forum which says its a misprint which makes sense as the correct is the same as every other application of this engine...
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531918 23rd Oct 2019 2:51pm
From the above video
Post #531920 23rd Oct 2019 4:05pm
Danwilderspin
yea should have prob done that too... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531921 23rd Oct 2019 4:35pm
MattHughes86
hi guys,
does any one know (i havent watched the video yet) which piston has to be at TDC for the rebuild of these engines so that the timing will be correct?
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #531963 24th Oct 2019 9:50am
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Doesn't work like that on the ajv8. The crank locking pin denotes "tdc" and can only fit in one position. HTH 2006 4.2 SC
Post #532011 24th Oct 2019 5:36pm
MattHughes86
cool thanks,
thats what i thought but the cam were 180 degrees out for locking so was a bit concerned.
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #532054 25th Oct 2019 8:38am
