Home > Technical (L322) > Electrical woes....
Rude
United Kingdom 2010 Range Rover Vogue SE TDV8 Alaska White
Electrical woes....
So it started with park assist. No longer assisting. Completely dead. Not even the camera. Not the button. And no sensors.
Now the entire radio/sat NAV thingy is playing up. Can’t play the radio, CD or anything. Can’t even change the time of the clock. Dead. As. A. Dodo. Is this rain related..? Aarrgggh. I can take it to a garage but if this is a simple standard double, can someone help...?
Rapidly going off this RR lifestyle.... ggrrrrr
Post #532972 2nd Nov 2019 5:16pm
take a look in the rear near side cubby and report back.. ... - .- -.
Post #532977 2nd Nov 2019 5:40pm
Rude
What should I be looking for?
Post #532979 2nd Nov 2019 5:53pm
wetness... ... - .- -.
Post #532980 2nd Nov 2019 6:00pm
Rude
Took a look. A little dirty only. No water. And nothing I could see. Picture here.
Post #532981 2nd Nov 2019 6:07pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Looks like someone nicked all of it to me!
Post #532990 2nd Nov 2019 8:42pm
Rude
There is the cubby on the other side too!
Post #532998 2nd Nov 2019 11:17pm
if its dry in there then that's good...
is the battery ok? ... - .- -.
Post #533007 3rd Nov 2019 9:18am
Rude
Yup. Battery is all good too...
This is annoying. I’m going to check each connection in the nearside cubby today. I wobbled a few and the radio/cd etc is not working again. Still no park assist though but at least the camera has started again!
May also have to give up and let a professional have a look
Post #533009 3rd Nov 2019 9:55am
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I suspect you will have a can bus fault.
If you plug an obd tool in it will probably report bcm lost coms with various modules.
Tracking it down could be tricky.
Check the n/s wing cabling, plus under the back seat where it goes around the wheel arch (the loom gets squashed here).
Then check under the front seats, make sure it's all dry and again for cable damage.
Those are the areas that I've seen reported as having cabling issues.
The modules are also very voltage sensitive, so if there is a poor powered or earth they will give coms issues. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #533089 4th Nov 2019 12:20am
Rude
Thanks John
Thats next weekend sorted!
I’ll report back when I have an answer.
Post #533095 4th Nov 2019 8:18am
