![]() | Home > Technical (L322) > Coolant Leak. Water Pump Leaking. |
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
have a look on http://new.lrcat.com has diagrams and part numbers for everything you might need. |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Thanks WB. Got some idea now about what it looks like.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1582 ![]() ![]() |
From the look of this pic, the fan or viscous coupling bolts onto it - look between the fan and the engine.
Not sure exactly where it is on your engine but they’re typically just about visible at the front of the engine towards the bottom. I have asked to have the old parts if I’m not sure about the garage/mechanic doing the work - might be worth doing that? |
Not sure if this is your engine but looking at pix on the 'net, I'm not sure you'll be able to see it without removing the engine cover.
Thanks all. Very useful. |
