![]() | Home > General (L405) > 405s with high ish miles |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
As the owner of 100K miles 4.4 I find it very depressing |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Mine is just about to pass 70,000 miles after 25 months and I’ve every intention of running it for many years yet. Well maintained, there’s no reason why it shouldn’t clock 300,000 to 400,000 miles (or beyond) before it’s worn out |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
Is the 4.4 the better motor to have?
A lot of people are very happy with their V6’s. It makes a nice noise, uses less fuel (around 4-5mpg in practice), is apparently as fast as the TDV8 in the L333, but crank failures are, sadly, well documented.
I'm sure it's great, but the 4.4 V8 exists - therefore I could not bring myself to even test drive a 3.0 V6 |
I test drove a V6 and then took a V8 out. I had only turned it through 180 degrees in the dealer’s car park when I knew that there was no choice to make. Many say that the V6 has all the power you ever need; true, but on that basis a 2 litre four has “all the power you’ll ever need” |
Overfinchbespoke Member Since: 04 May 2010 Location: Wirral Posts: 77 ![]() ![]() ![]() |
Hi all
I don't know much about the 5.0 but they generally have lower mileage - as much to do with economy/cost as anything else.
High mile, premium vehicles are usually run by MD's of a company, serviced through a maintenace plan so could be a good purchase.
SlumberingSloth Member Since: 07 Nov 2019 Location: Dundee Scotland Posts: 3 ![]() ![]() ![]() |
I'm currently in the process of buying a 90,000 mile one owner full MD service history L405 from a main dealer, upon reading various blogs I have asked for a two year warranty (given) a service and fresh MOT (given) all paint scratches touched up (completed) and an update to the satnav (£180).
Congratulations, sounds good! |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Diff and transfer box oil change at the 5year service (80k)
I would be doing yours now if i were wanting to keep her very long term sir... Just my 2peneth for what its worth ![]() |
