![]() | Home > Technical (L322) > Differences in later style led dash |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757 ![]() ![]() |
The digital speedometer has to be enabled with a GAP IID tool. As far as I know it didn't come enabled as standard on any model.
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
Thanks.
Sadly you need to find someone with a IID tool pro as the standard IID tool is locked to a vehicles VIN number. The pro version doesn't have this restriction.
ok, good to know. Thanks. Too many toys, not enough time
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
I would recommend buying your own IID as it is invaluable for all sort of diagnosis, fault clearing, live value reading and CCF changes such as DRL and the Digital Speedo.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
If you mean this digital speedo - yes it’s IID tool that will enable it. There are also 15 other speedo designs but I haven’t gone through them all yet as it takes too long to change the CCF files and everything resets. The first one I tried changed the Rev Counter to a supercharged one though!
Yep that's the one.
