Home > Wheels & Tyres > Wheel questions
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Wheel questions
Hi,
I'm Looking to run a 2nd set of wheels with winter tyres on.
I see a lot of talk about different wheel styles, and sizes, but not entirely sure if they are all interchangeable.
My 2010 car has AB black wheels (essentially westminster wheels but diamond cut).
I'm unclear what the actual rim width and offset is, but tyre size is 255.50R20.
I see others fitting 21" and 22" wheels from presumably the 405 (and maybe RR sport).
These seem to be 275/45R21 or 275/40R22 tyre sizes.
Are the 405 wheels the same as sport ones in terms of offset and pcd ?
If not, how do you tell which is which ?
Will all these wheels fit the L322, or are they too wide ?
If you swap the wheels over, do you need to tell the car it has a different set of wheels on for tpms and diameter, or does it just deal with it?
Trying to avoid buying an expensive set of garage ornaments Whistle
Cheers,
John. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #534079 13th Nov 2019 2:52pm
John w
Admins can you delete this thread please, now it's been moved I've found the answers in other threads in this section Embarassed Whistle Too many toys, not enough time
Post #534148 13th Nov 2019 9:45pm
