![]() | Home > General > After purchasing used - first things to check? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
First of all we need pics!
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701 ![]() ![]() ![]() |
Speaking of gearbox's, perhaps look at a 'mega flush' rather than an oil & filter change?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883 ![]() ![]() ![]() |
I have just put up a post for a bargain Sprinter jack.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351 ![]() ![]() ![]() |
Megaflush gearbox. Bodsy is your man. Mobile out of Telford.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Check credit rating and savings.. although you probably should have done this before purchasing a ff.
Treat yourself:
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
Thanks all. I did have the oil drain mod on my radar but mine doesn’t smoke at all, so maybe already been done
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Have the 4 boost hoses been upgraded to the silicon hoses? Easy to check, just lift off the engine cover and look at the 'donut' on top of the engine. The 4 small length hoses are easy to spot, the originals split and give you the 'restricted performance' error. If not done, it's a simple and cheap fix, but will improve your car's performance and your peace of mind. Done mine and what a difference!! |
Everything I’ve done is on here:
One other thing to check......swollen nuts!! |
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 161 ![]() ![]() ![]() |
Good tip on the wheel nuts, where did you get your replacements from? Thanks |
Swollen nuts on my list |
Got a good quality set from fleabay, just make sure they are the right type and size for your model. |
Got a link for some recommended nuts? Mine were bad, some I had to use a 23mm socket! Also hard to get off! |
