Home > Technical (L405) > One way folding mirrors |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Have you changed anything with the IID TOOL I recently? I had a similar issue with the mirrors in my L405 after a change in the CCF files ,( completely unrelated to the mirrors).
23rd Nov 2019 9:00am |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
Thanks for the reply Dolph, a fair assumption however I don't use an IID tool. I did change the primary battery not so long ago and maybe that's caused the mirror problem, although the other niggles had pre-existed for a few weeks. I haven't renewed the secondary battery as there's very little info on the spec or guidance on changing, plus I'm not sure whether it needs changing as I don't know if this battery is monitored for its state of charge as well as the primary battery. Can't see the spec without disconnecting and removal which I'm a bit reluctant to do. All I know is it's a fairly large battery, unlike later models which I believe have a much smaller one. Other aspects of the infotainment are fine such as radio, TV, physical cd play, ipod and general settings, cameras etc. I guess the sensible move is get it checked out during the next MD service. |
23rd Nov 2019 1:01pm |
2015 4.4 AB
23rd Nov 2019 8:56pm |
Edit......being the chivalrous chap I am, opened the rear o/s door for a lady passenger today and the mirrors unfolded. Subsequently tried a few times with no problem so it seems to be the drivers door rather than a general issue. |
29th Nov 2019 8:30pm |
