Home > Maintenance & Mods (L322) > What Lies Beneath !
mercs600
England 2002 Range Rover Vogue Td6 Java Black
What Lies Beneath !
Attached are a couple of photos showing what was hidden by the side plastic trim at the rear of the vehicle (front of the rear arches) , recommended to check yours . My welder is fabricating new repair panels as there are non available on the market. One side I had a company who specialise in accident repair and are a UK wide repairer , they quoted me £400 each side and what we have found is the broke all plastic trim retaining clips and just used 'no nails' to refit the trim , and rather tan replace metal just used filer !!! They asked if I wanted a 'quick' job to sell the car or a 'proper' repair - I went for the later and this filler job is what I got ! Censored I will attach
further photos as the job progress.
Post #535729 28th Nov 2019 1:34pm
Mr Tee
yup, a truly dreadful piece of design. Had to get my old 02 welded for an MOT, utter horror story under the covers
Post #535734 28th Nov 2019 2:51pm
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
I would recommend everybody to remove inner wheel plastic covers (you can do this in lift without removing wheel) and check for rust. My left side was little rusty (only surface rust) so i brushed it and painted with hammerite spray in three coats. Right side was without rust but i put also three coats there just to be sure. This is a 2 hour job, so not much time consuming, but you will prolong your vehicle life. Also after painting, you can spray special wax for extra rust protection Smile RR HSE 4.4 2006 LPG
Post #536114 2nd Dec 2019 9:13am
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Yikes ! Shocked Shocked Shocked Shocked Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #536147 2nd Dec 2019 2:29pm
200AD
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Very keen to see how this progresses. Hat off to you for going for repair rather than moving the car on. I need to do this job on my own car, but will have to wait til spring as my garage isn't big enough to get the car in so will be working outdoors.
I'll probably have a go at fabricating the panels over the winter though.
Cheers
Andy
Post #536212 2nd Dec 2019 11:43pm
Post #536216 3rd Dec 2019 12:48am
mercs600
I have put a further update on another similar post with a link to the welder/fabricators Facebook page showing before and after pictures. Absolutely fantastic work , cannot praise or recommend him highly enough !
Post #536229 3rd Dec 2019 9:49am
