Home > Maintenance & Mods (L322) > m62 chain guides idlers etc
alfy
United Kingdom 2004 Range Rover Vogue 4.4 V8 Stornoway Grey
sorry if this has been spoken of before i searched and couldnt find anything.
my 05 plate m62 4.4 v8 petrol/lpg is currently being naughty and has thrown her timing chains and guides out of the pram.
after all the usual dramas of siezed viscous fan hubs and skinned knuckles i finally got to see the wood for the trees and have noticed a couple of things
oil pump chain is pretty loose, should i just adjust or better to replace?
the idlers attached to the tensioners have play and 1 has very slight grumble, i cannot seem to find the part numbers for them would anyone here be kind enough to help out?. all 3 of the idlers carry the same numbers and even google is no help
finally does anybody sell complete kits including all the guides, tensioners, gaskets, seals and o-rings for this job or is it a tedious job shopping around a number of suppliers hoping for someone to have more than one piece available?
thanks
guys
Post #536598 6th Dec 2019 9:46pm
rjff
For parts a fair place to start is Advanced Factors, site sponsor. You may get a discount and they can advise on what is necessary.
https://www.advancedfactors.co.uk/44-v8-pe...-220-c.asp
And, personally, if you're in there, replace anything suspect. Cheers
Richard
Gap IIDBT
Post #536610 6th Dec 2019 11:18pm
