Home > In Car Electronics (L322) > Bluetooth conversion on l332 mulf
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
Hi guys
I have converted my l322 to Bluetooth using a Gen 9 bmw mulf.
I have seen several comments around saying that you should use a Gen 13 mulf.
Can anyone tell me what improvements I would achieve by changing to a Gen 13 ? Mine works fine apart from no text messages on it.
Thanks
Post #536684 7th Dec 2019 10:11pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Not sure, probably best to look on BMW forums, I have a 12 for sale if you need one. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #536841 9th Dec 2019 10:04pm
horsedentist
Does the Sms work on version 12 do you know?
Post #536850 9th Dec 2019 10:30pm
Bushy30
I'm not sure what you mean 'work with sms'
The unit is 'mit ses' which is with voice activation, but I think yours is too Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #536852 9th Dec 2019 10:36pm
horsedentist
Text messaging everything on my iPhone works on the head unit except the text messages don’t come up.
Post #536853 9th Dec 2019 10:38pm
Bushy30
Still a bit lost, what would the head unit do? Play a notification that you have a message?
Sorry, not an iPhone user! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #536854 9th Dec 2019 10:45pm
horsedentist
Yes you can also read the message on there and write a reply. When I got the mulf I could read all the text messages that were stored on it from the previous user but it doesn’t register the ones coming in on my phone.
Post #536858 9th Dec 2019 11:32pm
mjdronfield
I put one in my TD6 and I’ve a feeling that text messages used to work and then they stopped. Think it was a software update on the phone that broke it. Things have moved on now, and newer SMS versions/standards etc won’t work on the ULF, as it’s too old now. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #536862 9th Dec 2019 11:51pm
Bushy30
Most likely MJD.
HD, if you're ever up my way, why not drop in, we can swap the units and see what happens Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #536863 9th Dec 2019 11:54pm
horsedentist
Cheers for that it’s just that I had seen Old write ups on the net where people had said they had it working. That’s probably the answer then new tech has passed them by. The later ulf are so expensive didn’t want to buy one if it won’t do anything more than mine already does.
Post #536878 10th Dec 2019 9:08am
mjdronfield
I think the main benefit of a later one is that it’s compatible with later phones.
Though I think Baris on this forum can upgrade the firmware to make it Gen 13....if I remember right anyway.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #536923 10th Dec 2019 6:05pm
Bushy30
I think you are correct Sir
Offer to plug in a later one stands, if it helps! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #536924 10th Dec 2019 6:21pm
Weegie
Don't know whether it applies in this case but when I had my Td6 I refreshed my bluetooth module using the Gap iid to overcome a problem. John
GAP iiD BT-Sold
Post #536925 10th Dec 2019 6:26pm
