![]() | Home > Technical (L322) > L322 2002 M62 bmw v8 help and advise needed, |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3267 ![]() ![]() ![]() |
when you disconnected battery did you touch the 2 wires together a la reset instruction in the wiki? |
sunbeam Member Since: 08 Dec 2019 Location: lancashire Posts: 5 ![]() ![]() ![]() |
Do you have link to it. |
Fond the problem, the wires from thermostat housing sensor have melted up to the ECU I believe its not uncommon for this to happen on these BMW M62 engines, no wonder I could not connect to ecu with my scanner. |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1045 ![]() ![]() |
Well done in finding that one thermostat wires are a common issue on these engines mainly the electrical connector failing due to water leakage. If you havnt done it all ready do the stat mod while your there don't use a standard state housing and swop out all the water hoses before they fail on you due to excessive heat. |
Thanks for your reply, I now need to change the engine loom due to the melted wires up to the ecu I just hope the ecu is still ok ?, I was going to replace the stat housing with the cooler running one and a new rad while I am at it. |
