![]() | Home > Maintenance & Mods (L322) > Front strut air bags |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
How do you know the shocks are OK? Have they been on the car for 15 years ? .
Phils Member Since: 01 Aug 2016 Location: North west Posts: 71 ![]() ![]() ![]() |
Struts are good. They do not need to be replaced. |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
went through the same drama, started with the airbags from maxxspeed or something like that, didn't work, they were cheap and leaking when arrived, |
Andy2986 Member Since: 26 May 2019 Location: Suffolk Posts: 117 ![]() ![]() ![]() |
Hi,
That’s good to know, I did see them and also from aerosus. Both based in uk.
I had aerosus airbags, they were a bad fit and leaked, they reimbursed me the purchase, but not the costs for the garage. They came from germany. |
Well that’s them out then.... |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
It's easier to change the whole strut , and is a diy job if you can free the bottom bolt mine was seized solid ended up at the garage but if you've got heat room and a scaffold bar you might get it , it's worth getting new drop links as they are a pain to get off and is quicker with an angle grinder rebuild with pots of anti-seize grease |
I am afraid I am old school and I don’t beleive in throwing away items that are still fully functional. Taking the bags off is just one more nut and a clip.
Hi
