![]() | Home > Technical (L322) > 2004 L322 multiple can bus faults? ABS ECU Dead - Update |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
have you got lpg? Current stable:
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 ![]() ![]() ![]() |
No lpg Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
ok forget that then... Current stable:
I’ve got a pretty big ‘water ingress’ somewhere. The spare wheel well swims - so am wondering if that is the issue. Now tracing it and finding what is ‘corroded’ is the problem. Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
So I have had to return the abs ecu once again and it is now pronounced unrepairable - suggesting possible can bus system software error, and parts not available. I am loathed to buy a recon unit in case there is something else tha is causing the problem.
invisible999 Member Since: 14 Jan 2024 Location: Reno, NV Posts: 58 ![]() ![]() ![]() |
This is 5 year old thread but how did you fix the problem? |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 823 ![]() ![]() ![]() |
i would like to know that too RR 2005 4.4 petrol
