Home > In Car Electronics (L322) > No display
markyp
England 2004 Range Rover Vogue Td6 Zambezi Silver
No display
Morning Gents , Got in the car today to be greeted by this,
Any ideas ? T I A 2004 vogue
1978 Pontiac Firebird
2010 Fiesta
Post #537171 12th Dec 2019 12:20pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Did you get any resolve to your issue , I have the same , perhaps it’s too long ago
Post #572801 14th Nov 2020 5:50pm
i experienced a 'dim' screen in my TD6 due to a low battery voltage ..i would start by checking that first just to eliminate it. ... - .- -.
Post #572807 14th Nov 2020 6:32pm
Also check all your connections in the boot - left hand side as you look in - all the electronics are in there & sometimes it's just a poor connection.
Post #572808 14th Nov 2020 6:40pm
alfapat
Yes thanks , I have had a new battery for a few months now, have removed and replaced most of the plugs in the rear , I do think it may be something simple in the end , but it’s finding it lol .
The gap tool I thought should be able to reset or reboot , but I can’t work that on out.
Post #572839 14th Nov 2020 11:36pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
If the MOST bus is optical, check that you have a red light coming out of the end as it should be a complete circuit. You would need to unplug each optical lead in turn, if you find no light then there is a failure on one of the components or lead. Go back to where you last saw the light and bypass the fault using the biro truck (plenty written about that on the forum) and see if the light now reaches the next connector 2011 TDV8 Vogue SE
Post #572860 15th Nov 2020 10:30am
alfapat
I reckon my system doesn't have optical as I have 2004 model, Thanks .
Post #572863 15th Nov 2020 11:07am
markyp
Hi, I never did find out the problem as soon after the screen went blank The car suffered a
Major electrical breakdown , basically everything in the rear left hand compartment stopped
Working followed by both front air bags splitting. So the car was sold to someone braver than
Me to sort out. Good luck Thumbs Up 2004 vogue
2010 Fiesta
Post #572980 16th Nov 2020 4:16am
alfapat
Just had a thought , if the units or unit controlling the monitor on the dash has not shut down properly when I removed the battery negative , would there be a reset button on either the monitor or unit in the boot to reboot the system.
Post #572983 16th Nov 2020 10:42am
dennij
Also just had a thought, might be nothing though. I remember watching a Wheeler Dealers episode where they had an early L322 that had the same issue as yours, Edd replaced the sat nav unit and all started working again. 2011 TDV8 Vogue SE
Post #572990 16th Nov 2020 11:25am
alfapat
Ok I’ll try and unplug the unit.
Post #572993 16th Nov 2020 12:30pm
dennij
Had a dig around the web for you and others seem to mention the silver entertainment unit in the boot. Corrosion can occur on the blue connector. 2011 TDV8 Vogue SE
Post #572994 16th Nov 2020 12:49pm
alfapat
Many thanks , I will check it.
Plug ok mot changed anything .
Post #572997 16th Nov 2020 1:29pm
alfapat
Would that be the silver unit or DVD player?
I’ve just unplugged the DVD unit , still have a backlight in the monitor but still no screen
Post #572999 16th Nov 2020 1:39pm
mjdronfield
DVD player? Not as standard fit there isn’t. If the sat Nav has been upgraded to the mk4 unit by a previous owner, it will have a DVD logo on the front.... the units can daisy chain, so you should be able to take a unit out the loop....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #573000 16th Nov 2020 2:10pm
