Home > Technical (L322) > Auto Vs Command Shift - 1st to 2nd? Differences? 8sp TDV8
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Hi all
Since my flush / gearbox reset I've had some strange behaviour most likely related to the learning process. However something doesnt seem to be improving and I'm trying to work out if it is normal behaviour or not. I didn't have the car long enough before having the flush to recall what it was like before.
So, from a standstill, gentle acceleration through 1st to second. In auto, when it changes to 2nd the revs hardly drop back at all. But if I do the same thing with the paddles the difference is more significant.
I'd love to know if this is normal and happens on them all. Or whether this is a sign of an issue.
No errors on the IID tool. Mine is a 2012 TDV8. 1 week since flush/reset, about 200miles covered, mixed driving. Tried some procedures to help with learning.
Post #537181 12th Dec 2019 1:24pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Why not drop over my way, drive mine, should give you a comparison Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #537183 12th Dec 2019 1:51pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Hi M@r]{,
I’ve also got a 2012 TDV8 and have observed the following:
1) when the drive train is cold the shifts between 1/2 are noticeable, can be felt and I deem it clunky.
2) when slowing down, for example, to a Roundabout and the car shifts down, the lower the shift - from 4/3 or 3/2 I can feel it ‘clunk’ - happens when hot or cold.
3) when accelerating at road legal/perfectly normal speeds, the gear box shifts whilst revs are maintained at approx 1800-2000 rpm through the lower gears until it can settle down in a higher gear and much lower revs. I don’t like this, it’s not like normal 4/5 speed auto boxes I’ve had before. It almost feels like it’s a CVT transmission, where the revs are held. But the shifts are seamless. Kinda as you describe.
4) I prefer command shift as I prefer to ‘change up’ normally before the car does (sometimes it won’t let me)
5) gearbox oil was changed by LR 20k ago.
6) when cold the box makes the car feel like it’s ‘hanging’ a much discussed topic by Dodge Ram owners.
To summarise, I think they are a good gearbox but need to be warmed up first.
Hope that helps,
Tom. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #537185 12th Dec 2019 2:00pm
M@r]{
Thanks both
Bushy: if I find myself over Oxfordshire way I may take you up on that, thanks for the offer
Tommy: so sounds like mine is reacting the same as yours, so suggesting this is normal behaviour. Although on normal use when cold I'm not getting the clunks / rough changes. The odd one maybe, but I think that is down to it learning still.
Post #537204 12th Dec 2019 4:53pm
mjdronfield
I know the gearbox holds on to gears longer when the engine is cold, to help it warm up quicker. It’s designed to do that.
It can also skip gears when changing down, say go from 5th straight to 2nd for example.
Might explain some behaviour?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #537208 12th Dec 2019 5:59pm
