Home > Off Topic > Network / wifi
GGDR
Network / wifi
I've got a bit of an iffy wifi room, of course furthest from the router.
Since I have an old BT Home Hub 3 lying around, I googled "bt home hub 5 as wireless repeater"
and there are plenty of search results....
But these all seem to require a cable from the primary router/hub.
Searched but can't seem to find if I can I do it just on wireless?
Or do I need another black box of some type?
Many thanks in advance team Thumbs Up
. Cheers, Greg
Post #537345 14th Dec 2019 10:41am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Wireless repeaters are generally not very reliable. Is there any way you can get a cable a bit closer to the problem room than the current access point?
What type is your primary access point? Ubiquiti do a long range version which is good although I've now changed to Mikrotik. Repositioning the main AP and replacing it with a dedicated model may solve the problem. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #537346 14th Dec 2019 10:49am
ilard
Connect your two routers over you power cables.
For example, get the devolo dLAN 1200+ Powerline Starter Kit. Plug one in to your main router via Ethernet, the other to your secondary router via Ethernet. Yes, your secondary router will need to be in repeater mode, specifically disable DHCP and stuff. I can’t remember the settings, but you’ll find them.
https://www.amazon.co.uk/dp/B00N8W349Q
Performance will depend on the quality of your cabling, but you will get at least some signal to your old Hub 3. The reason I suggest devolo is their reliability, they can stay up for months without needing a reboot. In my experience other brands are noticeably inferior.
Set your two routers up to use the same SSID and password so you can roam around the house seamlessly. The BT routers are pretty good, but it’s not going to be amazing, I expect it will do fine. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #537359 14th Dec 2019 12:18pm
mpirie
+1 to using mains power cable to carry network traffic.
I use the same method to give me WiFi in the garage......BT WiFi extender.
Mike
Post #537360 14th Dec 2019 12:22pm
GGDR
Thx guys
Can't run cable.
My primary is a Home Hub 5
Mike which one do you have, is it: BT Essentials Wi-Fi Extender 300 ?
https://shop.bt.com/products/bt-essentials...-CM40.html
Seems I can get a single unit repeater like the above which picks up the existing wifi, then relays it on.
or I can go with a power line set up with a plug in at one end and another plug in at the other end?
or third option upgrade my main router to something more powerful.
Those seem my three options, have I got that right?
. Cheers, Greg
Post #537426 14th Dec 2019 7:33pm
mpirie
The one I have may not be around anymore, but I plug one part into the wall socket and connect an rj45 ethernet cable to it from the router and in the garage have another unit plugged into the wall giving a WiFi signal to the garage and outdoors.
I think it was called the BT ethernet WiFi extender 500.
There's a piece of software you can download from BT that lets you manage the setup.
Mike
PS to use a repeater, you would need to be on the edge of you WiFi signal to have something to repeat. With the ethernet over power, you can have WiFi wherever your mains reaches. Be aware though, both the source and receiver units need to be on the same mains circuit, so if your buildings have different power sources, this solution may not work.
PPS looking at the BT site Greg, I think the extender 600 is closer to my setup. I think you'd be hard pressed to get a more powerful transmitter without a licence as the emitted power (eirp) is controlled by regulation, otherwise every provider and their dog would be selling high power transceivers.
Post #537431 14th Dec 2019 8:26pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
I've previously used the Netgear equivalents of that BT Wireless Extender in multiple houses to successfully extend coverage where it was patchy before. Not quite as good as a proper wired extension or using the mains power cables, but they worked well enough for us.
We've now completely changed the setup in both the houses, so not using them anymore. Not sure I'll be in central London this week at all, but if you happen to pass Canary Wharf you're very welcome to one, as they are just sitting on a shelf!
Post #537439 14th Dec 2019 9:34pm
MikeO
Another option to consider is mesh WiFi which is designed to use a back channel to extend the WiFi range.
Ultimately it depends what speed / reliability you hope / need to achieve. I have 300Mbps connection so i spent a lot of time trying to ensure I could make best use of it in areas where I most needed it.
Powerline ethernet in my house was just too slow but that may be down to my wiring as I have an old cottage which had been extended so the wiring is a bit of a mix.
One central AP and another on the front of the house gives me a high speed connection almost everywhere. I get > 100Mbps in my garage office. 2016 Skoda Octavia VRS Estate
Post #537444 14th Dec 2019 10:39pm
GGDR
Thanks all.
Thinking about going for a power line, probably this one:
TP-Link TL-WPA7510KIT Dual Band Gigabit AC750 Powerline Adapter Starter Kit
https://www.amazon.co.uk/dp/B0723C86CX/ref=emc_b_5_t?th=1
Which is dual band 2.4 & 5 ghz
My broadband is around 450mps (copper)
My wiring is all new, 5 years ago so hope that should work ok.
I don't want to have to switch wifi on devices but these TP-Link ones seem to have wifi cloning.
. Cheers, Greg
Post #537446 14th Dec 2019 11:15pm
MikeO
I'll be interested to know how you get on. The speeds quoted on the box for those AV line adapters are laughable. Best case I was getting about 20Mbps. My fibre modem is on a spur though which probably has a detrimental effect. 2016 Skoda Octavia VRS Estate
Post #537451 15th Dec 2019 12:21am
ilard
I recommended devolo powerline kit for a reason... use TP-link if you want to compromise reliability for price. Not worth it in my experience.
I no longer use powerline stuff, I ran Ethernet throughout my place under the floors etc and have a Ubiquiti UniFi network in every room, plus outside on the patio etc. It’s brilliant, but totting it up I think I spent a grand just on the UniFi kit in the end!! It was a labour of love.
But I gifted my devolo kit to my mother and it continues to provide rock solid connectivity, which is importance in my absence... I can’t be there every week or two fixing things. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #537454 15th Dec 2019 12:49am
ilard
If you want powerline with WiFi (I.e. not use your old BT Hub 3), then this is the devolo equivalent to what you pasted above:
https://www.amazon.co.uk/dp/B07H5TL9ZC
I don’t know if th WiFi would reach as far as the Hub 3 would, I suspect not. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #537455 15th Dec 2019 12:54am
Mr Tee
Have the devolo kit, works very well, use it for sky box & ps4, way better than WiFi
Post #537461 15th Dec 2019 7:56am
GGDR
ok thx chaps.
ilard - this looks good, thx for linking the correct one.
I'm not sure this does 'cloning' as the TP-Link says. Which is repeating login/network name/password as I don't want to have to switch networks as we move around the house.
I've read through all the info (even the manual Shocked ) for Devolo but can't see any mention of this.
Or do they all do that?
Also unsure why I need (up to) 1200 mps if my copper broadband is only 450 ?
I do have a NAS to pipe movies to all the TVs so I realise that is something I may need speed over and above 450 for.
Also future-proofing.
Any tips on these finer points really appreciated.
You find yourself having to become an unwitting IT expert, esp. that's the expectation anyway! Thumbs Up
. Cheers, Greg
Post #537481 15th Dec 2019 10:54am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Hi Greg,
Some of what is being said isn't quite correct.
I'll PM you.
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #537482 15th Dec 2019 11:11am
