![]() | Home > Technical (L322) > DPF diary B.B. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
Just thought it worth sharing my latest DPF figures, just for comparison.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Have you ever had a yellow DPF light come up? Just wondered why you’re worried about monitoring the numbers?
Rob,
Gotcha |
Davlyn Member Since: 21 Nov 2011 Location: Sladesbridge, Cornwall Posts: 236 ![]() ![]() ![]() |
Mike, what are you using to interrogate the ECU to give that level of data? |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
He's using a GAP iiDtool 2011 (MY12) 4.4 TDV8 Vogue
I have my iPad mini Bluetooth connected to my Gap iid and select the relevant live values, then just take screen dumps to keep a diary.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3951 ![]() ![]() ![]() |
I do both short trips and long trips (for example today did about 60mls each way)but seldom went over 70mph |
Leesbay Member Since: 05 Dec 2019 Location: Rainford Posts: 53 ![]() ![]() ![]() |
⬆️Yes as long as its above approx 50mph for 10mins plus👍 |
Yes, but you should also regularly rag it above 2500rpm to get the second turbo working and clear the crap out of the engine. Nothing to do with DPF but such a lazy engine they rarely get the taps opened up fully |
Geoff,
neilly Member Since: 06 Oct 2019 Location: Oxon Posts: 79 ![]() ![]() ![]() |
In the New Year, I will have to check mine for a week and see how it goes, as I have a daily 85 Mile commute , 80 Miles of it on Mway. I like this sort of thing. Cheers |
Yep, I do that using the paddles to knock it down a few gears on the motorway ![]() |
