Home > Technical (L322) > 12V ignition for DRL Lights
L_G_D
Poland 2008 Range Rover Vogue TDV8 Stornoway Grey
Hi, can U give me an advice from where I can give 12V over ignition for DRL lights. Is there any pin in the main electric box.
Post #537475 15th Dec 2019 10:09am
found this in my info archive ,
right side [near side] headlight wiring
ignition live- green/blue
headlight dipped feed- yellow/green ... - .- -.
Post #537478 15th Dec 2019 10:23am
wayneg
If you are fitting aftermarket DRL`s I would suggest using a fused DRL controller connected direct to the battery
https://www.ebay.co.uk/itm/Drl-Controller-...SwFMtcxjHS 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #537479 15th Dec 2019 10:28am
L_G_D
Thnx. I must buy this drl module.
Post #537490 15th Dec 2019 11:47am
