![]() | Home > Technical (L322) > L322 2007 suspension workaround/how to disable suspension |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2752 ![]() ![]() |
Rear junction box fuse 5R (20A) will prevent valve operation. CJB fuse 10P (5A) is the ignition supply which when removed will prevent the regular annoying warning messages, leaving only the initial warning message on start-up.
kirk05 Member Since: 25 Jul 2018 Location: Aberdeenshire Posts: 14 ![]() ![]() ![]() |
Great thanks GraemeS...I took out the 20A fuse which was in the passenger side fuse box & the fuse F22 (60A) which was in the rear fuse box.
Sorry, I looked-up the 2010 diagram rather than the 07-09 diagram. 57P should be the 20A and 7P the suspension ecu ignition sense. The 60A in the rear is for the compressor relay so removing that wasn't necessary.
Perfect ok thanks, will put the 60A fuse back in.
