Home > Maintenance & Mods (L405) > Side steps playing up
supershuttle
Where do you lube these things, mine sometimes will not retract other times will not deploy (Drivers Side). I've looked, there are no stones caught up in there a quick spray with 3in1 sometimes gets an improvement but it doesn't last. I suspect it needs some thicker grease but where? Geoff
Post #538241 22nd Dec 2019 5:52pm
andygts
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
Original WD40.
I've got into the habit of doing mine everytime I clean it, I've got some fairly horrendous country lanes round here so always give the hinges a good jetwash when cleaning and then give them a good dose of WD40 on and inbetween anything that moves. I can just reach the door handles when laid down next to the car so I work the steps at the same time as spraying. Current
2001 Porsche 911 Turbo
_____________________________________
Previous
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #538242 22nd Dec 2019 6:26pm
fin
Mine seam not to deploy when I park in one certain car park that has some large pot holes and bumps, each time I go in there they never open, anyone else had this?
Post #538892 30th Dec 2019 10:53am
SS.Lyria
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Loire Blue
It’s funny you should say that. Mine have not deployed twice. Both times when parked on a slope and both road surfaces cobbled and pitted.
I would expect it not to operate in certain terrain response modes, but normal mode?
Can’t seem to find the answer but can they detect uneven surfaces?
Post #538907 30th Dec 2019 1:04pm
