Home > Maintenance & Mods (L322) > IID Tool BT is it the tool or me |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1127 |
Why will my IID BT not pick up that I have a suspension fault? It has been updated in the last 3 weeks I am still getting a yellow triangle warning and briefly a red then went off back to yellow checked and no faults are shown?
25th Dec 2019 9:36am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 508 |
Did you scan for error codes across all ECUs? 2016 Skoda Octavia VRS Estate
25th Dec 2019 12:12pm |
Yes I did the Advance scan all ecu`s still no errors |
25th Dec 2019 12:15pm |
No errors in any ECU? That does seem a bit unusual in my experience at least
25th Dec 2019 1:42pm |
Well I stand corrected I discounted the same two that are always their door speaker not working and door lock but they have been showing since I bought the IID Tool not Checked any live values yet just driving me up the wall? |
25th Dec 2019 3:38pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4219 |
You may just have a dud tool? Does happen. Maybe get in touch in Pat at Gap....? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
25th Dec 2019 3:49pm |
That`s my next thought after the festive season see if he can come up with anything? |
25th Dec 2019 5:22pm |
Defo worth an email 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
25th Dec 2019 5:31pm |
Couple of thoughts. You could try checking ECU Info's for the suspension module to see if it's recognised and communicating okay. Or temporarily changing a suspension height just to check the IID is able to communicate with the suspension module.
25th Dec 2019 6:03pm |
OK, this morning I thought I would try the car with changing the suspension height? I started the car put the car into `N` selected off road and selected raise height up she went, Held the raise height button and up she went pressed the button again to come down which it did and the to access height all ok? So what did I do well yesterday when under the bonnet I noticed that the wires from the adaptive suspension were out from the holder with the rubber grommet which I had replaced with new from Duckworths So I checked both sides that they were ok, put it back together closed the bonnet until this morning and as said before no bong. I will test drive later could it be that simple? |
26th Dec 2019 10:36am |
