![]() | Home > Technical (L405) > Small rear seat not folding |
| karba78 Member Since: 21 Mar 2020 Location: Plaisir Posts: 105
yes great, not sure what aa or ab means and if the part would work... does anyone know ? according to ebay looks it for diesel 4.4 only... 2013 L405 V8 5.0 Aspirated Autobiography gone 2005 LR3 V8 4.4 HSE 1999 TD5 Defender |
i am afraid i am going to have to replace the connectors from the male plug. they are also rusted, anyone knows where i could find them
| recordman Member Since: 08 May 2013 Location: Kent Posts: 122
This breaker has a used 'AB' from a 5.0 Jag XJ for £100
million thks recordman, thats my part |
while cleaning the connector, i found 2 cut wires
found them
will keep you posted on progress, |
so ..
| Mikeerhymes Member Since: 01 Sep 2018 Location: Manchester Posts: 29
What was the issue in the end? Or was the main dealer update the way to go? Cheers |
| Foxie Member Since: 22 Jun 2024 Location: Kernow Posts: 13
New to Ownership... Just three days in now.
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 |
I'm not sure what car you have, but there is a module in the spare wheel area on the left side after you remove the lining. 2017 SDV8 4.4 silicon silver AB
Thank You TT.
Finally had chance to have a look... I can't find the whereabouts of the rear LH module as suggested. Finally discovered idiot-proof description of it location. The LH/near-side seat will not fold down from the rear boot controls or adjust from the side seat controls. Merely looking for the module to check electrical contacts etc.
Found this... For anyone else looking for info. https://static.nhtsa.gov/odi/tsbs/2015/SB-10105913-9430.pdf Turn's out there is no module in place what-so-ever!! That'll be why the seat is inoperable!!! Now into the throws of new module and programming in.. 2014 SDV8 4.4 Santorini AB |
Annoying but easy fix in the end for me, looking under the seat I could see a disconnected cable. The car had the fuel tank replaced by the MD, I suspect they didn’t put the seat connections back correctly after removing…. |
