Home > Technical (L322) > New vehicle to me
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
New vehicle to me
Hello. I have just collected a new to me 2012 Westminster and have been trying to go through everything on it which is a pretty big job! It all seems to be ok and as much as I can check all seems to work as it should.
One thing I can't find though is a key for locking wheel nuts. There is a location for one by the spare wheel. On closer inspection though it doesn't seem to have any fitted ? I'm not sure what they normally look like. Could anyone confirm please, many thanks
[/img]
Post #538728 28th Dec 2019 6:42pm
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Yours doesn't appear to have any....mine didn't either...
Post #538730 28th Dec 2019 6:50pm
DrRob
You dont have any. Like me the previous owner must have ditched them as they can cause a lot of grief. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #538731 28th Dec 2019 7:05pm
4040
Thank you for confirming. I just didn’t want to get caught out if I had a puncture and no means to get the wheel off!
Post #538739 28th Dec 2019 8:52pm
Go round and check all the nuts.
Check the wheel brace will fit on them all. If not order some replacements. They swell up and are just as tricky to remove at the side of the road as a locking nut if your brace doesn’t fit.
If you have a couple of larger ones, then use a larger socket to get them off. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #538745 28th Dec 2019 9:47pm
4040
Yes that’s a good idea. A job for the morning along with checking the FBH pre heat function. I’m no stranger to Land Rover products but this is my first Range Rover and there are an awful lot of functions to check! I did check most prior to purchase but you can’t remember everything.
There is so much information here, it’s a great help for new owners
Post #538749 28th Dec 2019 10:19pm
Nuts on that pic look OK, but it’s worth checking. Just had to remove one off mine with a garage, welder and several sacrificial tools..... Big Cry There is nothing that can't be fixed with a hammer😜😜
Post #538750 28th Dec 2019 10:29pm
4040
A picture of the vehicle. It’s in pretty good shape and have done nearly 300 miles in it today with no problems other than the key fob battery needed replacing
There are a few small jobs I want to get done including new centres for those wheels
It’s on 64k and has FSH but you never really know what something is like until you have run it for a while. Fingers crossed I did the right thing!
One thing I notice is that it has reclining rear seats. I haven’t seen many with that.
Post #538753 28th Dec 2019 10:42pm
Nice Thumbs Up
Not too many with the reclining rear seats. nice option to have. There is nothing that can't be fixed with a hammer😜😜
Post #538757 28th Dec 2019 11:36pm
