Home > Technical (L322) > Suspension fault / Adaptive Dynamic Fault
Smiggy
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
My first real issue since buying the car a year ago.
I have a suspension fault which flags up.
The car sits at normal hight but will not go up or down.
Just after the suspension fault pings the Adaptive Dynamic Fault appears.
Here's the iid faults
Post #539226 2nd Jan 2020 7:58pm
Smiggy
C1A00-1D can be caused by rear air suspension control unit.
So clutching at straws I have order a new one.
Does anyone know if the adaptive dynamics fault will be fixed if I get the suspension working g correctly again???
Post #539229 2nd Jan 2020 8:05pm
Mikem
United Kingdom 2010 Range Rover Vogue TDV8 Atacama Sand
I had the active dynamic fault come replaced the front cables on the front strut tops but the fault was still there so could not access any of the special programs eventually the fault was found out to be the rear ride height sensor had gone had a new one fitted job done
Post #539244 2nd Jan 2020 10:12pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Those are all invalid data received from modules. Sounds more like a can bus fault to me but would check modules first, as the first fault might well be a clue though. Circuit current out of range could be a short, poor connection, or one of the modules drawing too much. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #539260 3rd Jan 2020 12:52am
Smiggy
Looks like I have solved the issue.
I disconnected the rear air valve block sprayed the connector with wd40 and plugged it back it.
Cleared the codes and all the errors went.
I have been driving it round for the last couple of days with no issues.
On to the next problem. Very Happy
Post #539349 4th Jan 2020 8:40am
