Home > Maintenance & Mods (L322) > L322 Towbar, does a 2008 towbar fit the 2010 model yr? |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Yes and no! -- It'll fit, but you're likely to need to fabricate some 'L' shaped brackets for exhaust hangers. Current: 2011 FFRR Vogue SE 4.4 TDV8
6th Jan 2020 10:05am |
Cool mate, thanks for the tip. In that case I may go for the new one I think, prices are pretty close so no reason to go second hand then. MY 2010 5.0 SC Galway green and sand interior!!
7th Jan 2020 8:41am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
I've got an old one. Can I just bolt some L shaped hangers to the ends?
7th Jan 2020 3:16pm |
Yes, you should be able to ! Those brackets were on my strengtheners -- so simply took an angle grinder, removed from the strengtheners and bolted them up with the old style towbar
7th Jan 2020 4:28pm |
Aha. I have got a spare set of strengtheners so will look at that. Cheers! 2010 4.4 TDV8 Vogue SE |
13th Jan 2020 2:27pm |
