Home > Technical (L322) > Crankshaft Position Sensor (CKP)
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Can anyone help with instructions for locating and replacing the Crankshaft Position Sensor (CKP) on a 2006 4.4L petrol AJV8 Range Rover. Photos/diagrams would be great.
Thanks for any assistance There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #540036 10th Jan 2020 12:46pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Hello,
as long as its in the same place as the 4.2 then its at the back of the engine on the bottom, in a little recess and at the top of that recess.
it should also be shown in the WSM from the wiki.
i had to properly double check to get at mine as if i remeber right there is a cross memeber in the way also.
Matt
P.S. can crawl under the car at the moment to take photo as my back is a bit duff If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #540043 10th Jan 2020 2:03pm
rej
Thank you for the info. I'll take a look as soon as the ground dries up a bit. Is it possible without removing the undertays or do they all have to come off for access? There is a difference between knowing your sh!t and knowing you're sh!t
Post #540413 13th Jan 2020 11:34am
MattHughes86
trays will def need to come off im afraid.
Matt If In Doubt Give It A Clout
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #540427 13th Jan 2020 12:41pm
rej
Rear tray only removed. Took less than 5 mins to swap the sensors with the vehicle in off road mode and on a set of ramps Nice easy job and much quicker than I thought.
Thanks for the help. There is a difference between knowing your sh!t and knowing you're sh!t
Post #540656 15th Jan 2020 12:43pm
Danwilderspin
Aside from eml what symptoms did you get? Rough idle? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #541350 21st Jan 2020 11:58pm
Danwilderspin
What faults did you have to make you change this?
I’m getting intermittent starting? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633197 29th May 2022 10:30pm
kevinp
Hi Dan, I had a Ford Explorer that had intermittent starting and it turned out to be the electrical plug onto the crank sensor was dirty/corroded. A quick clean up of the plug cured it completely. Worth a try?
Post #633234 30th May 2022 12:44pm
Danwilderspin
If it’s not silly money I will buy a sensor too and clean it all and fit - just trying to get hold of Rob at duckworths now Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633237 30th May 2022 12:55pm
