Home > Technical (L322) > Sub woofer vibration in boot
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
I've had an annoying rattle/ vibration from the subwoofer area when I turn the volume up a bit. It occurs with the bass nots so is definitely related to the sub.
After much messing about, I've tracked it down to the removable trim panel in the boot which hides the sat nav DVD and all the othe electronic gubbins on the left hand side of the boot.
If I leave the trim panel off, no vibration noise.
Obviously this panel is removable but I want to be able to leave it in place. How can I secure it better so it doesn't vibrate?
Post #540846 17th Jan 2020 9:05am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Could you fit some draught excluder foam strip to give it some cushioning when in place. You can buy it in black so should blend in OK
Post #540851 17th Jan 2020 9:41am
