![]() | Home > Technical (L322) > Pulsing Sensation when towing |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
Never had an issue towing a caravan circa 1500 kg. Might be worth trying to use sport selection on box next time. Could also be a trailer issue although your wife may have felt that. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
[quote="Westminster_Bri"]
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
In drive the box reverts to auto after the 10-15 seconds if you don't select another gear, as OP says.
Westminster_Bri Member Since: 17 Jun 2019 Location: Gloucestershire Posts: 31 ![]() ![]() ![]() |
It was a hired trailer that went back this morning, but a binding brake on the trailer was something I had thought of...
I've used mine to select lower gears for some engine braking and it has never done that. Maybe I've got a problem? ![]() ![]() 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
Ours is a 2003 model and I think it does the same. If the lever is moved over to 'Sport' mode and gear changes are made manually, I think that if the gear s are not changed within a certain time it does revert to Auto mode, although still in Sport mode.
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
What mileage are you on?
That's probably why mine acted as I said as I was only using it for engine braking so didn't open the throttle until I was looking to increase speed at which point I would knock it into auto. ![]() 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
Interesting, I'm at 105K so maybe its time to fork out... |
Mine was generally driving fine (not towing). Slight pulsing when towing horses, approx 2 tonnes. It gradually got worse, especially up hill. The car started to hunt for gears and there was a sense of clutch slipping.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Change the oil and filter on the autobox, this problem should go away. Mine used to do this when going uphill, gearbox service sorted it. |
Would strongly recommend seeking out a mega flush rather than just draining the oil pan and refilling. This only changes about half the transmission fluid. Mega flush removes all the old fluid, flushes decontaminantss out then refills with new fluid.
