![]() | Home > Maintenance & Mods (L322) > Should I avoid these oil brands for gearbox fluid? |
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 ![]() ![]() ![]() |
IMO. Use recommended only. False economy using spurious oils. Just my two bobs' worth. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
+1
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
jm1489 Member Since: 09 Dec 2019 Location: Lincolnshire Posts: 48 ![]() ![]() ![]() |
Hi Phil,
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 780 ![]() ![]() |
Have a look at the many posts from RRPhil, his knowledge of these boxes seems second to none. Ignoring his impartial (unlike the suppliers) advice is not wise, however it’s your car,your choice and your money. |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
I used non-oem but correct spec oil, it sorted my shift issues and surging, gearbox is now very smooth and works as it should, has done for over 10k miles.
Thank you for a useful real life reply, think too many peeps are hung up on paying extra for brand names. Not planning to service and forget, as with you I will invest in some "proper" stuff before I consider gearbox as a job done. |
