Home > Maintenance & Mods (L322) > Key FOB Battery
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
Key FOB Battery
For my 2002 L322, both keys are giving the "Low Key Battery" warning on the info LCD.
The owners manual (well the NAS version I found as a PDF online for the 2003 model) says this is an easy DIY job, take out a couple of screws, remove coin cell and replace with Panasonic 2016.
But I'm also reading about all kinds of voodoo involving resyncing keys and things generally going pear-shaped...
What is the correct info ie can I simply remove the old battery from the fob and replace or is there some real risk of something unpleasant occurring? "Gloria" 2002 L322 Voguish V8 LPG - carcass
"Jessica" 1996 Disco 1 300 TDi Auto
"Harriet" 1994 Disco 1 300 TDi Manual - Gone
"Daisy" 1992 Disco 1 200 TDi Manual - Gone
Post #542107 27th Jan 2020 11:53pm
1. Don't do both keys at the same time (just to be on the safe side)
2. Don't change the key battery when the car is locked
3. Ensure you can manually unlock the car with the key (driver's door)
4. Just changing the key battery should not affect the remote syncing
5. Just changing the key battery should not affect the immobiliser, even if you lose remote sync you should still be able to unlock the car (manually - the alarm will sound until key in ignition and turned) and start it
6. If it does the remote-syncing is not difficult, but it can take several goes to get it right
https://www.fullfatrr.com/forum/topic47293.html (11th post down for the procedure) .
Post #542111 28th Jan 2020 1:00am
fenlander
Top man Thumbs Up
What a fantastic resource this forum is Very Happy "Gloria" 2002 L322 Voguish V8 LPG - carcass
Post #542112 28th Jan 2020 1:02am
