Home > Maintenance & Mods (L322) > What fixing goes in here?
Simmoto
United Kingdom 2010 Range Rover Vogue TDV8 Rimini Red
Appreciate it if anyone knows what goes in this hole in the front flap? I am guessing it is a fixing to the sidestep behind but maybe it's just a plug? Various clips, screws and bolts hold the rest of it on...no captive nut behind and the hole is blind so is it a fir tree clip of some kind maybe?
Thanks
Post #542397 30th Jan 2020 10:57am
stuart_2006
On mine there's a large washer and a cross-head screw - presumably a self tapper that goes into a hole drilled into the sidestep.
On the subject of mud flaps, what are those bits that come out near the fixing holes?
[img]https://cdn11.bigcommerce.com/s-fqaftp/images/stencil/500x659/products/23482/24082/CAS500060PMA__99448.1566292757.jpg?c=2[/img]
Post #542568 31st Jan 2020 8:16pm
Simmoto
Thanks, can't see your photo mate, not sure which bit you're asking about.
Cheers
Post #542573 31st Jan 2020 8:41pm
stuart_2006
Lets try that again. The sticky-out bits by the screw holes:
https://cdn11.bigcommerce.com/s-fqaftp/ima...57.jpg?c=2
Post #542574 31st Jan 2020 9:01pm
millerj90
The tabs fold back behind the wing and are secured by the screws.
This might help-
Post #542576 31st Jan 2020 9:18pm
Simmoto
Yes what you said Very Happy The y fold back and the screw goes through the hole and the tab
and underneath there's a plastic 'fir tree'
http://www.fullfatrr.com/gallery/albums/us...b_stud.JPG
Post #542578 31st Jan 2020 9:26pm
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
This thread is a classic and successful FFRR Treasure hunt Thumbs Up "Gloria" 2002 L322 Voguish V8 LPG - carcass
"Jessica" 1996 Disco 1 300 TDi Auto
"Harriet" 1994 Disco 1 300 TDi Manual - Gone
"Daisy" 1992 Disco 1 200 TDi Manual - Gone
Post #542579 31st Jan 2020 9:51pm
stuart_2006
So they just fold back and act as a spacer between the mudflap and body?
Post #542586 31st Jan 2020 10:24pm
Simmoto
Yes, on mine they are folded back as a spacer, assume this is correct but who knows?
Post #542598 1st Feb 2020 6:38am
