![]() | Home > Maintenance & Mods (L322) > L322 Headlight Query |
PovertySpec Member Since: 28 Nov 2019 Location: Durham Posts: 35 ![]() ![]() ![]() |
Hi all - quick question, on an 03 TD6, how many electrical plug connectors should there be connected on the back of the headlight unit? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35806 ![]() ![]() |
there might be info in the WM re this.. ... - .- -.
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
2. |
I was afraid this might be the case. The wiring for the lights at the front has been a source of ...amusement.... so far and although everything appears to be working, I have a “check dip beam” error. When I took everything apart to see if I could find any obvious issues, it looked to me that there should be another plug connected apart from the main one. I’ve double checked today and it looks like someone has spliced the wiring and joined cables together.
Right...I must admit, I’m a bit puzzled.
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 226 ![]() ![]() ![]() |
Begin to think somebody have change headlight units for later model. |
I think I agree. Having trawled some eBay listings I have found that there is a halogen headlight, with the one single connector on.
