Home > In Car Electronics (L322) > Aerial amplifier
Danwilderspin
Aerial amplifier
Just wondered if anyone can tell me if an 07 ff would have an amplified fm antenna? I want to buy one of these :
https://www.dabonwheels.co.uk/product/fm-a...-splitter/
But it say I’d need to disable the amplifier - if there is on any idea where it is? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #542956 4th Feb 2020 9:51am
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi what so basically you connect that to the existing amplifier in the car and you receive DAB broadcasts wouldn't you also need a DAB antenna? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #543007 4th Feb 2020 3:40pm
Danwilderspin
no I have an aftermarket dab receiver but this is just for the antenna so it claims you'd put the unamplified aerial signal from the fm into this and you're good to go... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #543009 4th Feb 2020 4:19pm
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
Here's my take on the Range Rover III radio.
L322 antennas are printed on the glass. Key fob, AM and 1 part of the twin FM come from the tailgate window, 2nd FM and old analog TV come from the left side rear window. Both antennas are amplified close to the glass. Both antennas are limited in frequency to the range of 0.5MHz (bottom of AM) to 450MHz (above key fob) while (UK) DAB is around 220MHz (above old analog TV and below the top of digital TV (700MHz). The key fob, analog TV, diversity FMs and AM are mixed just after the amplifiers.
The amplifiers have blocking filters for all signals below 0.4MHz and above 450MHz so you MAY be able to use a simple passive splitter for DAB. If not you will need to find substitue amplifiers that have 3 outputs - digital TV (includes key fob frequencies), DAB and AM/FM. Don't despare though, BMW, Mercedes, and a whole lot of other vehicles have the same problem so the demand will be fairly large.
Any techies out there that can confirm this ???
bye. 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia
Post #545183 26th Feb 2020 12:14am
