![]() | Home > General > Buying advice |
| Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181
Welcome to the forums
| Avi Member Since: 24 Sep 2010 Location: North West Posts: 309
Try and get a later 2005 with the facelifted front and the touchscreen nav. |
| Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199
td6's are fine, but:-
| POWARTEK Member Since: 02 Apr 2011 Location: Teesside Posts: 11 |
Thanks Tim, thats some good info there.
oh far too techy for me that lot! You will get some of the regulars coming along in the next few days who can answer most of that lot - I buy new or ex demo cars / late plate so I tend not to be so worried about these things as I still have warranty left to get them fixed, or the car isn't old enough for them to fail (hopefully!) 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
| Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313
The gearboxes are sealed for life - according to Land Rover. Which in the real world means change the fuild and filter every 60k miles as they usually go pop between 80k and 100k miles... |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
As far as I'm aware the gearbox is the same as in the 5series. The box is "sealed" for life thus having the problems and failures in later life. Nothing can run in it's own |
IIRC the "sealed for life"is now generally taken as sealed for the length of the factory warranty! If you look in the technical section somebody has just posted about changing their gearbox transmission fluid and filter 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Yer what Tim has said is true. Dan will pop along soon to let you know when GM recomend changing he oil in the box. They have reduced the service times recently I think. Unfortunatly you will drop into these areas if your looking at a 2004/05 car. |
Thanks for the advice, this is basically the same issues I'm having with my 5 atm. It's got over 100k on the auto box hence awaiting the hefty bill anytime I hear a squeak. |
| BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429
it would be well worth buying a facelift as it has a more powerful v8 and a new 6 speed box |
What year does the facelift model come start from and what's the smallest diesel engine it comes with? |
they started in 05 with the interior getting the MOST system etc and from 55 plate with the facelift
best bet for you is to go to http://www.rangerovers.net/rrmkiii.htm
| All times are GMT |
