Home > Wheels & Tyres > Road Force wheel balancing
kirton
England 2006 Range Rover Autobiography 4.4 V8 Zermatt Silver
Is it worth it on a FFRR?
Post #543315 7th Feb 2020 12:43pm
ur20v
A Trap
Do you have a problem? Normally correctly fitted tyres and straight wheels will balance normally and be fine on the ff
Post #543317 7th Feb 2020 1:09pm
kirton
I have just had four Cross Climates fitted (255/55/R19) and had Hunter four wheel alignment. The fronts were re-adjusted perfectly but the offside rear could not be adjusted because the bolts were heavily corroded and seized. It is rebooked for sorting out.
I just thought I might go the whole hog and have Road force balancing whilst there.
I also had a front lower suspension arm replaced prior to the new tyres.
On another note, i replaced the tyres one week earlier than was booked because there was a screw sticking out of the front near side adjacent to the tread wall edge. I use Oko in my tyres and I'm glad I did as I picked up the screw on a 200 mile round trip to a funeral, so the day was bad enough without being late for tyre repair/replacement.
Post #543320 7th Feb 2020 1:58pm
its a impressive job and if you suspect a bent alloy [as i did] it will show up...they move the tyre round the rim so its at its optimal balance position... ... - .- -.
Post #543332 7th Feb 2020 4:50pm
