![]() | Home > Maintenance & Mods (L322) > Cock a hoop !! |
| gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163
Totally agree. The cap should be available separately for about £7, I reckon!
| rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 569
Absolutely the cap should be available as a separate item. Having just replaced mine, on the up side at least the jets were correctly adjusted out of the box!! Drives:
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808
Not ideal but you can do a reasonable fix using a Mini rear jet. You have to get the remains of the original out then the mini one will push in and function quite well. I have a mist spray nozzel on the actual arm which works brilliantly but not the best looking if you look hard. 2007 TDV8 VSE
| All times are GMT |
