![]() | Home > Technical (L322) > Diagnostic tool |
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102
GAP IID diagnostic
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Cheapest place is island 4x4 |
| fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124
If you can find someone local and willing on the forum they can add your VIN to their GAP IIDToolBT for less than £100 to give full functionality, but to just read and clear codes then any GAPIIDToolBT should work already.
| mudknight Member Since: 21 Sep 2012 Location: birmingham Posts: 73
Thanks for the advice , yep tried the lock to lock trick but no good on this fault . Been looking at hawkeye red dongle . Anyone know if any good ? |
Britpart Lynx is almost as same full functionality as IID Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057
Buy a hawk eye cheap enuf 2nd hand on the bay or get the reset plug in tool 70 quid |
You may eventually find the fault is one or more ride height sensors, these are Hall Effect devices that do eventually wear out and give zro or "implausible" values to the ECU hence the error message- a (relatively) cheap fix that can be done without removing the front wheels, though again you will need some form of suitable diagnostic tool once the parts are replaced. |
| BMG Member Since: 26 Feb 2019 Location: Kent Posts: 203
icarsoft LR V 2.0 is around £130 and will read EAS codes ,clear them and provide live data.
| 4040 Member Since: 19 Sep 2019 Location: Cornwall Posts: 44
| kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 229
Foxwell nt 530 will read and clear codes, reset steering angle sensor, gearbox adaptions, alter suspension heights and a few other things I havent got round to looking at yet. |
| RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250
Autel AP 200 Bluetooth here, seems to do all of the above so far, linked to my onboard Android tablet.
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808
RichM63, can you confirm the Autel can change suspension heights permanently. Can it also do things like stop bulb testing 2007 TDV8 VSE
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 548
I have the earlier iCarSoft as well as an IID BT from Gap. In terms of capability the IID can also calibrate suspension heights (I know my iCarSoft can't do this, the V2 may be able to) and modify the CCF, flash modules etc. It is also a heck of a lot easier to use - they've put an enormous amount of effort into usability and it is a pleasure to use. Having said that, the iCarSoft is an excellent tool it's just a bit fiddly, slow and awkward to use compared to the IID. I'm sure the V2 is better and if all you want to do it read / clear codes then it's well worth the money. There are some on eBay - they make a good 2nd hand buy. 2016 Skoda Octavia VRS Estate <gone>2009 FF Vogue TDV8 Buckingham Blue</gone> <gone>2015 BMW 520D SE (not my favourite car)</gone> <gone>2009 D3 HSE Galway Green</gone> |
I bought the Autel AP200 in order to have a reader permanently in the L322, with full live data onto my Android tablet.
