![]() | Home > Technical (L322) > Coolant system getting pressurised |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Have you checked the other coolant pipes to see if heat is getting into them all, just a thought that you might have a blockage somewhere in the system. Is the radiator the same heat all over? |
nick4275 Member Since: 28 Sep 2018 Location: Bewdley Posts: 69 ![]() ![]() ![]() |
Thanks for the prompt reply.
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
Do these have an egr cooler? Cheers
Er, I’m no expert but I believe they do. Where might you be going with your thinking ? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16400 ![]() ![]() ![]() |
Sniff test is the best way forward Nick... |
I'm making a bit of headway. Got the chemical sniff test, sent it back as they sent me blue liquid type. Tested it today and the red liquid went yellow inside a couple of minutes.
Have a look at this guys videos as he has done what you want to do sir...
Thanks Craig,
Absolutely but it worked on his which was the main point 👍 |
So, 2 bottles of Steel Seal later and things are much better but still not right !
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
That sounds like a water pump issue, change the water pump and the thermostat. BMW i3 Electric Car
.. BMW i3 Electric Car
So i'm still going with this one.
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 77 ![]() ![]() |
My 2c just quickly...
