Home > Technical (L322) > Lower door moulding seal
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Hey guys,
I’ve just won on eBay a brand new lower door moulding, the lower panel of the doors on the l322 and the seal that comes with it.
Apparently the seal is loose and just slides on.
You can’t buy these seals separate but has anyone ever removed / replaced one?
I’m going to use the new seal on my existing door panel. Just don’t know if it should be glued or just slid into place?
Daz
[/b] Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #543812 13th Feb 2020 2:20pm
dazza1983
No one lol? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #543903 14th Feb 2020 4:48pm
322BLL
Estonia
Yes, I have removed it and put it back on when the plastic part needed new paint.
So you can just slide it into place easily and there will be gap between seal and plastic.
I don't remember anymore the order. Maybe it was first the door, then plastic and the clips that hold the plastic. Just check the other side and you will understand. You don't need glue or anything. Just need to install it correct way.
Post #544714 21st Feb 2020 4:24pm
