![]() | Home > Technical (L322) > SOLVED Noise comes right rear wheel when blower motor starts |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
FBH pump most likely. Cheers
flashgordon Member Since: 23 Sep 2019 Location: Hannover Posts: 76 ![]() ![]() |
What does “FBH“ mean?
Hi Flash
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 155 ![]() ![]() ![]() |
Hi Flash, FBH = Standheizung! What you hear is the fuel pump like riff already said. |
Thanks a lot |
I will read the manual today
The FBH itself is in the front under the battery, but the little pump that supplies the fuel to it is under the car near the tank at the rear. Thus you'll hear the clack clack at the rear.
very good help
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
The clicking of the FBH pump is normal.
As NMJ says, it certainly sounds as if it's working correctly, so why would you think of changing it?
I drove the RR for more than 20 miles today and found out that the noise indeed disappeared when engine was really warm
Glad it helped |
