Home > Technical (L405) > Driver's Seat Rubbing centre console
Heyloft
2019 Range Rover Vogue SE SDV8 Carpathian Grey
My driver's seat arm rest rubs on the centre console producing an annoying creak, like its an old bus.
It is the arm rest rubbing, the passenger side doesn't do it. If I gently pull the armrest away, it stops. The dealer says, there is nothing they can do, there is no adjustment for the seat.
So, it just does it. Rubbing on the console is normal? surely not ? Big Cry Wot's that in old money
Post #545027 24th Feb 2020 4:19pm
is the 'arm' not adjustable? ... - .- -.
Post #545033 24th Feb 2020 4:38pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
In my car there is more than a 1 cm gap between the armrests and the console. As in the attached photo.
Post #545047 24th Feb 2020 5:51pm
Heyloft
Sadly not in mine.
The drivers side is too close.
Post #545048 24th Feb 2020 6:22pm
is there a massive gap on the passenger side..maybe the console needs 'centring'.. ... - .- -.
Post #545049 24th Feb 2020 6:28pm
Heyloft
Not really !
Post #545051 24th Feb 2020 6:35pm
adara
This is how it's in mine:
Post #545055 24th Feb 2020 7:30pm
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi Heyloft,
From the pictures you supplied, it does look like it is a normal gap on the passenger side, but clearly not on the other.
Only two things I can think of;
1. Loosen the four torx-headed bolts holding the seat down and 'ease' the seat towards the drivers door, then nip the bolts back up again.
- if that doesn't work -
2. Stick a little piece of self-adhesive velcro (the fluffy side) to the side of the arm-rest where it (hopefully) can't be seen.
Or turn the stereo up.... Rolling with laughter
W. 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #545056 24th Feb 2020 7:36pm
Heyloft
Wrecker79 turning Stereo up doesn't work, once you've hear the noise/rattle, nothing will drown it out.
I'll try option 2, although the dealer said there was no possible movement available.
TBH I'm not sure they actually bothered with it, beyond looking at it Rolling Eyes Wot's that in old money
Post #545058 24th Feb 2020 7:43pm
Ash59
Have you measured the width of that arm rest it looks to have a bigger radius than all the other pictures
Post #545063 24th Feb 2020 8:07pm
Heyloft
Well spotted Ash59
I’ll check in a bit Thumbs Up Wot's that in old money
Post #545065 24th Feb 2020 8:14pm
Heyloft
Ash59 it was an optical illusion caused by camera position. They are both the same diameter. Wot's that in old money
Post #545218 26th Feb 2020 3:13pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Its not the centre console a bit off centre is it?
Post #545231 26th Feb 2020 6:21pm
Heyloft
Very difficult to tell really Wot's that in old money
Post #545232 26th Feb 2020 6:22pm
PaulTyrer
could you take a measurement from the inside face of the B Pillar to the edge of the centre console from each side? I know it wouldn't be 100%accurate unless you have a laser measure, but it might give you some idea.
Post #545233 26th Feb 2020 6:39pm
