![]() | Home > Technical (L322) > What does this part do? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
Fuel cooler PN LR031827. John
Double post John
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3267 ![]() ![]() ![]() |
thx John. is a leak likely to lead to RP? Even when not in RP it seems underpowered. Could it be a simple leak or is it more sinister?
If there is a leak then I would think that the fuel delivery would be affected which in turn could lead to RP and loss of performance. John
They are your fuel pipes James, coming from the diesel fuel cooler unit and should be under VERY high pressure sir... |
Thanks Craig. Have checked alignment and fitting - if they are high pressure lines do they have an o ring which could split/leak? |
