![]() | Home > Maintenance & Mods (L322) > Restricted performance |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Welcome |
| Tooltime79 Member Since: 03 Jun 2015 Location: York, North Yorkshire Posts: 27
The first thing I would try is to check the top inter cooler hoses which often get a small tear and cause the fault you have. They can be hard to see as the go in the bends so you might need to take off (2 jubilee clips) and inspect them.
| Neilacker Member Since: 02 Mar 2020 Location: Haydock island Posts: 21
Thanks I will check them tomorrow.
Read codes and check your hoses |
Icarsoft lr2 is not a bad little reader Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Thanks for the advice,
Excellent news! Get them silicone hoses on, clear the codes and hopefully job done |
Fingers crossed it's sorted. I've had it 3 years now and other than the alternator it's never let me down |
| TDSIX Member Since: 18 Feb 2017 Location: Stirlingshire Posts: 210
Well done. You are lucky.. last time I got 'restricted performance' and limp mode, it was a turbo actuator (engine out £,£££). 2010 FF 4.4 TDV8 Vogue - Gone
Got my new pipes fitted and all is as it should be, no more warning lights or limp mode 👍😁
| All times are GMT |
