Home > Technical (L322) > Bonnet not releasing / cable snapped / locked out? Solved.
TDSIX
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
Just overcome this problem myself.
Skill rating: 1* Easy
Tools required: Hammer
Problem: Bonnet not releasing on passenger side.
Cause: Cable snap.
Solution: The cable runs along the underside of the front cross member panel. Smash the front grille with the hammer and remove it completely, taking care not to damage the fan behind the grille. Reach in and find the cable (it is quite obvious) and pull it out. A tug upon the exposed broken wire with pliers should release the bonnet.
Other Info: If the wire has broken at the wrong end (at the mechanism), I believe removing the wheel and wheel arch liner may grant internal access to the lock mechanism using a long thin tool.
Hopefully this will help someone out in the future. It is my own method, I did not read this elsewhere. 2010 FF 4.4 TDV8 Vogue - Gone
2007 FF VSE 3.6 TDV8 - Gone
2011 RRS HSE 3.0 TDV6- Gone
2003 FF TD6 Vogue - Gone
2006 FF TD6 - Gone
2007 FF 3.6 VSE - For sale
2011 FF 4.4 TDV8 - Current
Post #545919 3rd Mar 2020 10:17pm
