Home > Technical (L322) > How the ZF8 works
GGDR
How the ZF8 works
Found this which , whilst pretty hard core technical, is written in plain-enough language to (nearly) understand.
Since quite a few of our RR's have the ZF 8-speed, thought I'd post it in case anyone wants to know exactly how their transmission works.
Quote:
Every gear change the ZF8 commands is one of these "clutch" to "clutch" shifts. The ZF8 has 5 of these, and has 3 active at a given time for the gears 1-8 and reverse. Park/Neutral has 2 active, so shifting from Neutral to Reverse/Drive has a single engagement.
So it releases one clutch and applies another to shift.
The releasing clutch is called the offgoing clutch, and the engaging one the oncoming clutch.
Depending on whether its an upshift or downshift, under power or coasting, the actual "stages" of shift are different, but those are mostly unimportant, and in the case of "under power" or "coasting" is mapped in tables as positive or negative torque.
First, understand that a clutch pack can hold a certain amount of torque depending on how much pressure its held together with. This pressure is transmitted by various means, but its usually a small chamber (a clutch chamber/volume) that has a piston that pushes the clutch packs together, and a spring that returns it back to open (so that with no pressure the chamber empties). By default, when you're driving down the road, the pressure doing this is the "line pressure". Higher pressure has higher torque capacity, but if you look at the line pressure table, you'll see they modify it as torque moves. Higher pressure requires the oil pump in the transmission to work harder, and causes more drag, so its controlled to have enough torque capacity but not excessively so, in order to keep efficiency high.
Now when a shift happens, we want to remove the torque capacity from one clutch, and transfer it to another. To reduce drag and improve efficiency again, we typically have clutches sitting empty to help minimize any movement they have when not active. So we have to fill our oncoming clutch, and empty our offgoing clutch, but do so in an organized manner so that we don't break anything inside the transmission and hold as much torque as we can during the shift, and go as quickly as we can.
So I'll divide the shift into a few sections:
Fill->Torque Transfer->Inertial Phase->Maintenance
Fill
During the fill phase, we fill the oncoming clutch with oil again, up until the point it starts actually building pressure in the chamber. Essentially the clutch solenoid valve targets a set "pressure" (really its just an opening of the valve, look at the characteristic curves for the solenoid)
There are actually three sub-phases: A prefill, where the ATF is pumped into the chamber just until it starts to hit resistance from the piston/spring, a fast fill to move the piston to move it so the clutches are just nearly touching, and a stable fill (we call just fill) that moves the clutch packs until they just "kiss" and have 0 torque capacity.
Tuning this stage is complex, and if you want to learn more, I'd suggest this paper: Dynamic Analysis and Control of the Clutch Filling Process in Clutch-to-Clutch Transmissions
There's a lot of math in here, but the ideas are also expressed in somewhat plain English if you'd like to learn more.
The time this takes we want to be as quick as possible, as its responsible for a big amount of delay we feel in a shift.
Torque Transfer
During this stage, we transfer the torque capacity from the offgoing clutch to the oncoming clutch. We do this using a targeted oncoming rate and pressure, and a targeted offgoing rate and pressure. Now, when calibrating we put in the oncoming target pressure and offgoing target pressure, as well as ramps.
These are however only guidelines, the transmission internally is trying to hit a targeted slip while doing this transfer (for the ZF8 I have not identified what this is or how its controlled, but I know it happens). So the transmission itself attempts to adapt these pressures while shifting to hit these goals.
At the finish of this stage, our oncoming clutch is now holding all the internal torque of the transmission, and the offgoing is holding none.
Really the only tuning parameter we have for this step is the Oncoming and Offgoing rates. And we only have the offgoing control during downshifts, during an upshift, we don't have control on the ZF, as its internally managing this to manage the RPM drop and internal slip.
I should mention, the oncoming clutch is still "slipping" at the end of this stage, but its now transferring full torque. This slipping is required as the output of the clutch isn't necessarily at the same speed as the input. Reducing this slip to zero is the goal of our NEXT phase.
Inertial/Slip Phase
This is the stage we normally think of as the "shift". Its when the engine speed starts to change (and in fact the speeds of all the stuff inside the transmission as well!) and we start to feel like we're shifting. During this phase, we're basically waiting for the oncoming clutches slip to reduce to zero. We do this by controlling its pressure.
Now that torque has been transferred internally, everything has to "catch up". These internal torques now act on new planetary gear sets, the input shaft, and turbine. During this step is when RPM actually drops or rises as the turbine drags the engine down or up. If you were wondering why our oncoming pressure is adjustable by gear, its because these internal torques change per gear.
So, we have a target slip time. This is how long we expect this ratio change to take up. If we want to speed up our perceived shift, we target a shorter time here. We likewise will need MORE oncoming pressure to deal with these higher internal torques. Likewise, this is where torque management comes into play in a very important regard. During an upshift, any torque the engine is producing has to be handled by the transmission in addition to what its already handling as internal components are speeding up or slowing down. By having increased engine torque, we have increased pressure desired, and we have increased the amount of energy that the oncoming clutch bears. To make this job easier, we have upshift torque management, to reduce the strain on the transmission, and in this case it will actually SPEED UP the process of the shift as we'll have less slip and energy to control. So we can actually complete our shift faster with the correct amount of torque management. Too little and we're harming things and slowing it down, too much and we're slowing the car down when it comes out of the shift unnecessarily.
On a downshift, we reverse this process a little, we actually want torque from the engine to help us speed up the shift (raise the engine RPM and rev match!). Too little and we're again just wasting time, and too much and we're overreving and causing excess wear as the clutch has to bring it back down.
But typically, faster slip times and more engine torque mean we need more clutch torque capacity, and so you see as we target more torque or faster shifts, our pressures increase.
As well, the offgoing clutch really shouldn't be apart of this phase. Once the oncoming clutch is handling torque, if the offgoing one was as well, we'd start to have parts of the transmission fight each other. This is called "tie-up" and slows our shift down (and puts a lot of strain on the gears and clutches!). Hopefully we picked good values while ramping it off previously!
Now if we don't apply enough oncoming pressure to handle everything, we might actually have the engine kind of overshoot its target RPM on shifts. We call this "flare" on a downshift (the engine overspeeds the target input speed before its brought down) and "slip" on an upshift (it feels like the engine kind of slowwwwly slides into gear). So, our goal here is to set pressures knowing our targeted shift time. Ultimately, we're limited by how much pressure we can generate, and the torque capacity of our clutches. The faster we want this phase to happen, the more internal torque we need to do so, and the higher the pressure and more slip we potentially face. OEMs balance this with comfort in mind as well. If this phase isn't smooth, the user feels it. A fast shift that's a little sloppy might have a burst of torque or a drop in it on the output shaft, and you feel this (the shift "chirps the tires" or "bogs down").
Most of your time tuning a transmission, your goal is to speed up shifts or change the quality of them, so you play a careful balancing act between shortening the slip time and increasing the pressure.
As well, internally there is adaption happening where the transmission is trying to adjust the oncoming pressure to hit the target slip time. If it has to adjust too far, you actually will get DTCs indicating clutch failures (and it'll even know which clutches are possibly failing because of the shifts it notices the problem on!
My best advice for tuning this is shortening the shift or reducing the torque management means more pressure is needed to handle the higher internal torques. If you allow flare or bogging to happen, all that energy is being dumped into the clutches wearing them out prematurely. There is an eventual limit where you simply can't go any faster before it happens that you will hit, and that's a limitation of the clutch materials and pressures you can apply. A beefier trans that can better handle those stresses is necessary, but then you may also have to retune all the low power shifts so they still feel soft and gentle Keep in mind raising the target pressure also extends the torque transfer phase, as you need more time to get the pressure and torque capacity to that level!
Maintenance
This phase is boring. Oncoming pressure is set to line pressure to make sure the clutch doesn't slip. During this step, its just making sure the oncoming clutch pressure allows zero slip. The offgoing clutch has no pressure applied, and is slowly draining away (there's an empty time that is mapped to indicate how long this takes).
Tuning this means tuning the line pressure tables.
I know thats a lot to digest, and if you want to learn more, I suggest taking a read of Virtual Clutch Controller for Clutch-to-Clutch Shifts in Planetary-Type Automatic Transmission.
While reverse engineering the ZF8, I found this to be very helpful in trying to figure out how they were managing the shifts and plotting them out.
Also as a quick aside to what "phase" you should target while tuning:
If you want the "delay" from when a shift is commanded to when you feel it "start", you need to tune the fill and torque transfer (ramp) phases. You don't feel anything happen until this completes and inertial transfer starts! An aside here, a lot of people perceive lots of transmissions to have long delays from the triggering a paddle to the "shift" happening. Most of the time, its not a hardcoded delay, but is actually these two phases executing. Part of what makes the ZF8 a great transmission is that it can accomplish both these phases very quickly, making it feel like when you press the paddle, it shifts right away!
If you want the "delay" as the ratio is changing to be different, you need to tune the inertial/slip phase. Keep in mind, the faster you want to do this, the more torque you see internally, the more energy the clutch sees, and the faster it can wear! This is balanced by OEMs to be comfortable and provide good service life. We may have different goals in mind in the aftermarket (or in fact beefed up the clutch packs so they can handle more energy!).
Hopefully that's as thorough as you need, or more than that. If you want to learn more, check out the links I provided.
From here:
https://forum.hptuners.com/showthread.php?...-Steven-HP Cheers, Greg
Post #546126 5th Mar 2020 9:52pm
mjdronfield
I took it for granted till I bought something British Rolling with laughter
Very interesting.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #546141 5th Mar 2020 11:54pm
Baltic Blue
Greg,
As you know, last week mine was somehow stuck in Park.
It could have been the main selector or the High/Low range selector.
I feel the problem was probably damp/wet electrics somehow but I haven’t been underneath to investigate further at this point in time.
I would love to hear any ideas of where the problem could lie.
Hopefully a squirt of WD 40 on the right connector could solve it??
Any other things to read would be most helpful, along with any expert guidance from anyone (RRPhil of 8speed?? Rolling with laughter
Cheers
Post #546255 7th Mar 2020 7:54am
RRPhil
I do have plans to do a teardown thread on the 8HP-70 (the next one in the series Very Happy )
ZF 5HP24 : https://www.rangerovers.net/threads/zf-5hp...ost-243365
GM 5L40-E : https://xoutpost.com/bmw-sav-forums/x5-e53...rdown.html
ZF 6HP26 : https://www.fullfatrr.com/forum/topic14798.html?
Magna-Steyr DD295 Transfer Box : https://www.fullfatrr.com/forum/topic12404.html?
I’ve already got the transmission, but just haven’t had the time to get on with it yet …
Phil
Post #546268 7th Mar 2020 10:48am
Baltic Blue
Brilliant, I look forward to reading every word, Phil.
If you come up with any ideas as to why mine should stick in Park after being stood unused for 5 weeks, I am all ears.
When I moved the selector from P to N, the N was flashing, not solid light., then after several attempts and changing high/ low selector several times the N stopped flashing and the car has been perfect all week since.
PS,
If you need someone to brew up whilst you work on it, I am only 30 minutes away up the M66. Rolling with laughter
Post #546298 7th Mar 2020 3:04pm
RRPhil
I guess most people will realise this, but it’s probably worth mentioning that the other four transmissions used in the L322 (i.e. ZF 5HP24, GM 5L40-E, ZF 6HP26 & ZF 6HP28) all employ a Bowden cable to operate the transmission gear selection mechanism/park lock, and therefore feature a traditional ‘gear lever’ for the driver to pull backwards and forwards.
The ZF 8HP70, introduced in 2010 in the 4.4 TDV8, was the first and only L322 transmission that rid itself of the cable and instead features an electronic rotary dial for the driver to input his gear requirements, grandly named the Electronic Transmission Selector (ETS).
For the park lock mechanism, all five transmissions use the ‘proven’ spring-loaded cone/ratchet system
but instead of the cable moving a lever, which turns the detent disc, which pulls and pushes the connecting rod which activates the park lock pawl, the 8HP70 instead uses two electronic solenoids and some hydraulics to control the application of the park lock mechanism.
During normal driving, the system is hydraulically disengaged by applying the park release solenoid, and mechanically secured by applying the park hold solenoid (which has fingers that mechanically ‘grab’ and hold onto the end of the park release valve).
To engage the park lock mechanism, both solenoids are turned ‘off’, and the park lock mechanism is engaged by a spring. In the event of electrical/electronic failure the park lock will automatically be engaged. An emergency park release mechanism therefore has to be provided, in case the battery is flat and the vehicle has to be moved. This is ‘hidden’ under the trim panel between the cubby box and the drinks holder.
Why the ‘mechanism’ should stick in Park when it is left for an extended period, I can only guess at. Possibly the park hold solenoid ‘fingers’ get a little arthritic after an extended period of time in the ‘open’ position and refuse to close together to grab the end of the park release valve until exercised a little, or maybe the hydraulics activated by the park release solenoid are failing to push the park release valve away from the spring applying the park lock so that the fingers can grab it? If this reoccurs, I would suggest it would be best to remove the Mechatronic unit from the sump and test the two solenoids and check for any issues with the park release valve mechanism.
Phil
Post #546379 7th Mar 2020 11:54pm
Trantorman
United Kingdom 2017 Range Rover Vogue SE SDV8 Aleutian Silver
Phil
once you have stripped and rebuilt that 8 speed box I would be interested in buying it if you wanted to sell it, I have one, which occasionally stutters, if you feather the throttle on approach to a junction, then accelerate because its clear to go, sometimes the gearbox will be in the wrong gear, it appears to drop down into a lower gear then realise, the roadspeed is too fast for the gear its selected and it all gets a bit lumpy, while its sorts its self out.
it does not do it every time just occasionally, but when it does its very noticeable.
its had 2 filter changes and fluid changes, there is no one up in the frozen north who can do flushes, it does not store any fault codes and works perfectly most of the time.
Any thoughts?
Post #546408 8th Mar 2020 9:54am
